multiple versions same computer
emsteel123
Post by emsteel123 » Sun Apr 12, 2009 7:05 am
I wasn't able to find this in the online doc. i have 1.3.4 on my system, windows xp, sp2. just downloaded the install for 1.3.7, can i have both installed on the same computer? can i open a project file from 1.3.4 in 1.3.7?
Thanks :D emsteel123
allencmcbride
Re: multiple versions same computer
Post by allencmcbride » Sun Apr 12, 2009 5:12 pm
As for your second question, you can definitely open a project file from 1.3.4 in 1.3.7. I've struggled myself with your first question. You definitely shouldn't run them both at the same time, and a lot of people here, but not all, will tell you that you can't have them installed at the same time. Among those who say you can't have them both installed at the same time, opinions seem to differ on just how thoroughly you need to uninstall an old 1.3 before installing a new 1.3. To be absolutely safe, delete the application itself, the preferences file, and your LAME and ffmpeg libraries before installing 1.3.7. --Allen
