Hi folks
I was recording all day with the same settings, same mic, same A>D converter, cables etc.
At one point I encounterd the distortion heard on the attached .aup file and I have no idea where it came from or how to fix it. I do know that clearing the file from the destop and re-recording stopped the distortion but a random problem like this can be disastrous.
Running Audacity 2.1.1
Windows 10
Presonus Audiobox directly wired to the computer.
Thanks in advance
Bob H
Distortion
Distortion
- Attachments
- Sample For Audacity Forum.aup
- (19.33 KiB) Downloaded 38 times
- Quality Assurance
Re: Distortion
An AUP file is not an audio file. Please see How to post an audio sample.
Also see http://manual.audacityteam.org/man/faq_ ... .html#sync - scroll down to "To fix speed drift, pitch and quality problems, try the following tips".
Re: Distortion
This is going to sound "defensive", but it's usually not "Audacity's fault". During recording, Audacity has a fairly simple task of capturing the audio data stream from the drivers and sending it to your hard drive in a particular format.but a random problem like this can be disastrous.
People who are serious about recording often have dedicated computer that doesn't get messed-with. If the computer's settings/configuration/applications aren't changed, you are less-likely to have random problems.
And if you're recording something critical where there's no chance of "take two", you should have a separate back-up system recording in parallel. (That 2nd recorder doesn't have to be a computer.) ...Computers are the least reliable gizmos we own! ...Mostly because we mess with them.
Re: Distortion
Attached audio sample
Note...a totally random problem..........one good recording.......(no setting changes).....one bad recording.
Audacity was closed and reopened.........next recording wa flawless
- Attachments
- Sample For Audacity Forum.mp3
- (1.23 MiB) Downloaded 23 times
- Quality Assurance
Re: Distortion
I think there is suspicion of dropouts so also look at http://wiki.audacityteam.org/wiki/Manag ... nd_Drivers.
