Calculating Music
eager to learn
Calculating Music
I'm trying to ascertain if Audacity, Excel, Libre Calc or any program will calculate all my music down to seconds and minutes?
Ex. 5,004 mp3 and/or .wav files - how many hours, minutes, seconds does that all add up to?
One - if I have each song in a spreadsheet with its respective time is there a process, program or application?
Two - if all my music is just listed in a folder on my hard drive running Windows 7 - 32bit - how can I import that all into an Excel spreadsheet to then search for all the time of all that music?
Thanks so much.
Thanks so much.
Re: Calculating Music
Winamp does that...
If I select all genres, all albums, and all artists at the bottom of the screen it says "16,322 items [51 Days + 9:45:06]".
Winamp is no longer being developed/updated, but you can still get it, it still works, and I'm still using it (on Win7 & Win 10).
P.S.
A little quick searching tells me Windows Media Player should be able to do it, and maybe iTunes too, although you might have to us a spreadsheet with iTunes.
P.S.
waxcylinder
No, iTunes just does it.DVDdoug wrote:A little quick searching tells me Windows Media Player should be able to do it, and maybe iTunes too, although you might have to us a spreadsheet with iTunes.
eager to learn
Hi,
I don't subscribe to iTunes.
Can you pls share a "trusted" link to Wimamp so I can download?
Thank you.
Thank you.
eager to learn
Thanks for the WinAmp link.
There are 5 links to WinAmp downloads - e.g. parched, unpatched
Which link of the 5 would you think would be best to download Winamp?
Thanks again.
Thanks again.
I don't know what the changes are, probably nothing "major". I have Winamp 5.65 on this Win7 32-bit machine that I'm on right now.
You don't have to "subscribe" to iTunes. As far as I can remember I've never given them a credit card number but I did register because I think you have to register to access their online database, and maybe I had to register to "synch" my iPod to iTunes. Just about the only thing I use iTunes for is to copy songs into my iPod.
eager to learn
DVD Doug,
Which of those 5 links do I click to download?
Thanks.
Thanks.
eager to learn
Hi dvdDoug,
Thank you so very much!
DVDdoug wrote:Try Winamp 5.666 Full (US English version) (from this page).
