Tinny sounding dynamic mic
Hi Audacity community,
I'm new to podcasting and to audacity. Recorded my second interview yesterday. It was in a hotel lobby so instead of using my better condenser mics I used a pair of backup Audio Technica MB3K hypercardioid dynamic vocal mics. They were effective in not picking up most of the background lobby noise, but when I play back the raw recording, our voices have a tinny, magnetic quality. It's hard to describe, and it's subtle, but I can definitely hear it.
Here is a link to an mp3 section of the recording: https://politypartners.files.wordpress. ... ection.mp3. Aside from importing the WAV file to AUD and then exporting to MP3 so I could post a link here, I haven't edited the audio at all,
I would love any advice about using EQ or some other effect to help get rid of that subtle tinny, magnetic sound.
Many thanks,
Josh
Many thanks,
Josh
Re: Tinny sounding dynamic mic
OK, so we have a field interview recording. How did you record it? On what? Model numbers?
Two microphones? Are they each on their own tracks, say Stereo Left has Microphone One, Stereo Right has Microphone Two?
It will take a minute to pull down the track for listening.
Koz, thanks for the quick response. I used two mics, each on their own mono track. (The MP3 is just one of the tracks, not both). Recorded it on a Zoom H6 then just transferred the WAV file to audacity on my laptop.
I don't think these are what you think they are—unless I got the wrong one.
Have you used these microphones before?
It's never a good sign when the ad says " High Output" and "Extended Response for Clarity."
That usually means overly crisp and sometimes harsh with higher distortion than you would think.
It's not hypercardioid. It's "unidirectional" which means most of the sound comes in from the front most of the time, but don't hold us to that. Real hypercardioid looks like reverse garden hose water. Unless you're right in front of it, zippo, nothing.
I think it's doing the best it can and if you didn't compare it to anything else, would work OK. There is a sibilance filter (SS SSS SSS) that I tried quickly, but I must have adjusted it wrong because it garbled the voice. It's a bit experimental.
I'll see if I can figure out who supplies the filter.
The voice clip has a 100Hz cut-off (rumble) filter applied. That's what I'd be doing with a field recording, but it can make male voices slightly gutless, particularly if they have a lot of gut (announcing voice). You can't bring that back without bringing up the room rumble.
Have you learned your lesson about how darn much fun it is to record in the field?
As we go.
As we go.
See if that's any better. Everything from "Scotsman" forward has a little anti-crisper applied. I can forward the custom curve I used to get that.
This is where we ask you how are you listening? I have a silly joke where if you can hold your speakers in one hand, you should probably get something else. Hollywood uses a particular Sony headphone for field use.
https://www.sweetwater.com/store/detail/MDR7506
I don't know that I would be listening to my Moody Blues collection on these, but if something goes wrong in a field shoot, I'm going to hear it before anybody else catches it.
- Attachments
- dynamic-mic-selection-Equalized.wav
- (1.25 MiB) Downloaded 39 times
There's sizzly interference on "very first windmill" I don't think anything can be done about that.JoshCohen wrote:... any advice about using EQ or some other effect to help get rid of that subtle tinny, magnetic sound.
DeClicking & DeEssing generally improves matters IMO.
Free DeClicker & DeEsser plugins for Audacity are here.
That's the correction suite I was looking for.
There's something wrong. Are you sure we got the right microphone? I found several listings for the Audio Technica MB3K and it's like they're describing different microphones. That and I can't find a factory data sheet.
To put this in perspective. I know people who have pulled off very difficult voice sound shoots with one of these.
https://www.bhphotovideo.com/c/product/ ... otgun.html
Something like that is what's likely to be inside this wind screen.
Ira Glass and his show This American Life was one of the first people to discover you could use a long-distance, shotgun microphone in hand-held configuration for an interview like that. It's possible to do that interview using older techniques, but it's more expensive, much more complicated, and for only marginal improvement in vocal quality. The shotgun technique took over because of its obvious simplicity and ability to deliver near-studio interviews in difficult conditions.
http://transom.org/
These people have some good ideas about voice recording.
http://transom.org/2016/composing-music ... ican-life/
http://transom.org/
Koz and Trebor, thank you both for your responses.
You're right that the mic is a discontinued model. It also makes sense that it''s unidirectional and not hypercardioid.
Here is the recording setup I used:
The condenser mic in the middle was just a backup; I am only using the two dynamic mics on the final edit. The Ira Glass shotgun method looks great but maybe more for a "man on the street" type of interview. For my limited budget I am trying to find a way to make my existing mics work the best they can.
The headphones I use are basic Tascam TH-02. The Sony pair looks great but I need to wait a bit to invest in those.
Koz, yes I am interested in the curve you used on your edit. My email is jcohen at politypartners dot com or you can message me on this forum.
Trebor thanks also for the link to those plugins.
Thanks again to both of you!
Josh
Josh
OK, well, if somebody had a gun and said I had to use your microphones....
I'd throw the mic stands away. The more backtime you have, the fancier you can make this.
I'd put a foot-square piece of plywood on a towel and put the microphone on that. This is just what I had in the garage.
With more backtime, I would drill about a one-inch, shallow hole in the middle of the board so I don't need the tape to keep the microphone from rolling away. Paint the board flat black and use Duvetyne instead of a towel.
This is the technique used with a simple lavalier microphone.
Duvetyne is Hollywood-speak for heavy flannel/felt, almost always dead black.
Why on earth would I do that? That's "fake" pressure zone configuration. It almost doesn't affect the quality of the microphone, but it doubles the volume of the voice. Not kidding. 6dB free volume boost. The towel isolates the microphone from desk, table and floor noises (unlike your stiff stands). Pressure Zone isn't subject to desk surface slap echoes and comb filtering effects (talking into a wine glass). Yes, you can get rid of those last two with a heavy towel or blanket on the desk, but this is easier.
If nobody had a gun and didn't care which microphone I used, I'd be using lavaliers.
I need to dig for that equalization filter...wrong machine.
