Please state:
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade (see
https://www.audacityteam.org/download/).
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
orschiro
- Operating System: OS X 10.9 Mavericks
Post
by orschiro » Sun May 21, 2017 5:32 am
Dear steve et al.,
Unfortunately it has been difficult to pin down the cause of this problem, so there is no fix as yet, which means that the problem will still be present in Audacity 2.1.3 which is due for release very soon.
Can you please point me to the relevant bug ticket?
Yours,
Robert
- Quality Assurance
Post
by Gale Andrews » Sun May 21, 2017 1:05 pm
orschiro wrote:Unfortunately it has been difficult to pin down the cause of this problem, so there is no fix as yet, which means that the problem will still be present in Audacity 2.1.3 which is due for release very soon.
http://bugzilla.audacityteam.org/show_bug.cgi?id=1315.
orschiro
Post
by orschiro » Mon May 22, 2017 4:17 am
Thank you very much, Gale!
bpkent
- Operating System: Linux Debian
Post
by bpkent » Sun Jul 30, 2017 11:44 am
Gale Andrews wrote:orschiro wrote:Unfortunately it has been difficult to pin down the cause of this problem, so there is no fix as yet, which means that the problem will still be present in Audacity 2.1.3 which is due for release very soon.
The cause may not have been pinned down, though a solution has been developed, and a patch is available for those that build from source
https://github.com/audacity/audacity/co ... bfbbdb2e99. With luck, it will be in the next release.
- Site Admin
Post
by steve » Mon Jul 31, 2017 8:11 am
bpkent wrote:The cause may not have been pinned down, though a solution has been developed, and a patch is available for those that build from source
A version of that fix has been committed to the Audacity source code, so manually patching is not required, and it will be in the next release.
