MacOS Sierra rejects installation of Audacity 2.1.2
Help for Audacity on macOS.
Puu
Post by Puu » Fri Mar 10, 2017 12:01 am
A message pops up that this is not Apple supported.
Old version 2.1.1 runs with Sierra
Any chance to get 2.1.2 running?
Re: MacOS Sierra rejects installation of Audacity 2.1.2
Post by kozikowski » Fri Mar 10, 2017 12:05 am
Apple > System Preferences > Security and Privacy > General. Is APP Store and Identified Developers selected?
Puu
Post by Puu » Fri Mar 10, 2017 12:11 am
Yes it is selected but now I got it!
Have to select open anyway!
Thanks!!!
