Air pods not syncing with audacity HELP
So I was in a coffee shop today and I just wanted to work on my audacity recordings with my new iphone air pods. However, when I went to listen, my air pods would not connect to my audacity recordings. I tried everything I could, but there was not even an option for me to choose my air pods as a out put source. Can you please help me? The air pods have no problem connecting to my iphone, and to my macbook pro and itunes and they were a gift. I would like to be able to use them as well as keep other strangers in the coffee shop from listening to my recordings. Please help. I feel like technology doesnt like me : (
Re: Air pods not syncing with audacity HELP
They mount as a bluetooth device, right? Can you see them in Mac System Preferences?
Apple (upper left) > System Preferences > Sound.
Put them in, connect them, make sure they work and then Start Audacity. Look for them in the Audacity Device Toolbar.
http://manual.audacityteam.org/man/device_toolbar.html
Audacity checks for devices when it starts. You can also Transport > Rescan...
They could be sticky because they're both earphones and microphone, right? I don't know how the Mac deals with that. Being wireless could be messy, too. I don't know how the Mac deals with a ratty connection.
Yes I can see them in the sound system on my computer and connect them, but when I start audacity, they are no there and there are no drop down options for them. So you think there is no way for audacity to connect?
- Quality Assurance
Audacity doesn't support bluetooth all that well. And you might have an old version of Audacity - you didn't give your version. See the pink panel at the top of the page.cemachek wrote:Yes I can see them in the sound system on my computer and connect them, but when I start audacity, they are no there and there are no drop down options for them. So you think there is no way for audacity to connect?
I have 2.1.2 and a macbook pro 2013 with op system macOS Sierra 10.12.3
I am having the same issue. I find that Adobe Audition works - my AirPods show up as an option on the output devices there. But in Audacity this bluetooth device doesn't show up as an option and choosing "built-in output" doesn't work. I'm using the most recent version of MacOS with Audacity 2.1.1.
- Quality Assurance
Please put numbers to the most recent version of macOS, for complete clarity. 10.12.3 ?prowsej wrote:I am having the same issue. I find that Adobe Audition works - my AirPods show up as an option on the output devices there. But in Audacity this bluetooth device doesn't show up as an option and choosing "built-in output" doesn't work. I'm using the most recent version of MacOS with Audacity 2.1.1.
- Quality Assurance
Does it help, each time before launching Audacity, to go to System Sound Preferences and reselect AirPods as default output device (even if already selected)?cemachek wrote:Yes I can see them in the sound system on my computer and connect them, but when I start audacity, they are no there and there are no drop down options for them. So you think there is no way for audacity to connect?
no it still didn't do anything by selecting air pods
Any update on this? I'm suffering from the same problem
