Audio jack in windows 10 machine doesn't work
heanner
Post by heanner » Sat Feb 25, 2017 2:55 am
The audio jack works fine, but in Audacity, I plug in my headphones, but the sound still goes through the speakers. I've searched for a solution, not finding one
How do I solve this so that when I listen to audacity, I can listen through my headphones?
DVDdoug
Forum Crew
Re: Audio jack in windows 10 machine doesn't work
Post by DVDdoug » Sat Feb 25, 2017 5:08 am
That sounds like a hardware problem, or maybe a driver problem. If it's a new computer maybe you can return it or get it repaired.
I assume this is a laptop?
What does that mean?
Are your headphones regular analog headphones with a 3.5mm phone jack, or are they USB?
Robert2
Post by Robert2 » Sat Feb 25, 2017 12:05 pm
I had a similar problem on my Windows 10 PC. I solved it through free open source “AudioSwitch” (https://github.com/sirWest/AudioSwitch), which allows you to “switch between default audio input or output + change volume”.
Post by Gale Andrews » Sat Feb 25, 2017 1:09 pm
heanner wrote:The audio jack works fine, but in Audacity, I plug in my headphones, but the sound still goes through the speakers. I've searched for a solution, not finding one
If when you plug in the headphones you hear sound in the speakers and headphones, this could be a setting in your sound card. Hold Windows key down, press X and choose "Control Panel" then look under "Hardware and Sound" for your sound card's control panel.
heanner
Post by heanner » Sun Feb 26, 2017 12:19 am
DVDdoug wrote:That sounds like a hardware problem, or maybe a driver problem. If it's a new computer maybe you can return it or get it repaired.
It's a Surface 4.
heanner
Post by heanner » Sun Feb 26, 2017 12:21 am
It doesn't appear to be. If I listen to other programs or audio, sounds go to the earphones. But not with audacity. According to the settings, the jack is working properly.
heanner
Post by heanner » Sun Feb 26, 2017 3:14 am
Robert2 wrote:I had a similar problem on my Windows 10 PC. I solved it through free open source “AudioSwitch” (https://github.com/sirWest/AudioSwitch), which allows you to “switch between default audio input or output + change volume”.
I'm loathe to download this; what machine do you have?
Post by steve » Sun Feb 26, 2017 10:20 am
heanner wrote:I'm loathe to download this
I don't think you should need additional software in order to select the audio output.
See: https://www.microsoft.com/surface/en-us ... =undefined
Robert2
Post by Robert2 » Sun Feb 26, 2017 11:51 am
You don’t need it, but setting and resetting the default audio output in Windows 10 as I had to do was hell. It was convoluted and cumbersome. It involved plenty of clicks. It had to be repeated over and over again. With “AudioSwitch” (https://github.com/sirWest/AudioSwitch), it only takes 2 clicks to switch between speakers and headphones, and back if necessary. AudioSwitch is a safe harmless application. If it does not work or does not suit your needs, you can easily uninstall it. It is running fine in Windows 10 x64.
Post by Gale Andrews » Sun Feb 26, 2017 2:40 pm
Robert2 wrote:setting and resetting the default audio output in Windows 10 as I had to do was hell. It was convoluted and cumbersome. It involved plenty of clicks.
To be fair, the Anniversary Edition of Windows 10 lets you left-click the speaker icon then choose the playback device from a dropdown menu.
