Audacity "connects the dots" when you zoom in
brian-armstrong
Hi,
I'm reporting a bug I've noticed on the OSX version of Audacity, but it likely applies to all versions.
When you zoom in close enough to see individual samples, Audacity renders them with lines connecting them. However, DSP tells us specifically that you CAN'T do this. Audacity should instead plot these with a stem plot like Matlab does, or at least give the option to do so.
Otherwise, this is great software! Thanks for all the hard work.
Re: Audacity "connects the dots" when you zoom in
It's not a bug. The software is working as designed. It may be awkward or an error, but not a bug.I'm reporting a bug I've noticed on the OSX version of Audacity
brian-armstrong
Ah, that's a good point. Should I have posted this elsewhere?kozikowski wrote:It's not a bug. The software is working as designed. It may be awkward or an error, but not a bug.I'm reporting a bug I've noticed on the OSX version of Audacity
There's no perfect fit. I think "Audio Technology > Audio Processing" is the closest we have, so I've moved the topic here.brian-armstrong wrote:Should I have posted this elsewhere?
Could you post a screenshot showing how Matlab displays samples.brian-armstrong wrote:When you zoom in close enough to see individual samples, Audacity renders them with lines connecting them. However, DSP tells us specifically that you CAN'T do this. Audacity should instead plot these with a stem plot like Matlab does, or at least give the option to do so.
Probably the most "truthful" way to display samples would be like this:
but that's pretty useless in terms of "visualising" the data, which is the whole point of having a graphic representation of the audio track.
There's a related discussion here which you may find interesting: http://forum.audacityteam.org/viewtopic ... =converter
brian-armstrong
I have made an attempt to show what I mean.
http://imgur.com/a/Ul0yC shows it at various zoom levels. The first is before showIndividualPoints engages, and it looks like it's kind of an awkward transition to this style. Also weird is the "space filling" and aliasing you see at lower zoom levels, though I think it looks ok zoomed far in. Might make an interesting non-default render option
Code: Select all
diff --git a/src/TrackArtist.cpp b/src/TrackArtist.cpp
index 7d4385d..584b856 100644
--- a/src/TrackArtist.cpp
+++ b/src/TrackArtist.cpp
@@ -1363,12 +1363,13 @@ void TrackArtist::DrawIndividualSamples(wxDC &dc, int leftOffset, const wxRect &
// Draw lines
- for (decltype(slen) s = 0; s < slen - 1; s++) {
+ for (decltype(slen) s = 0; s < slen; s++) {
AColor::Line(dc,
rect.x + xpos[s], rect.y + ypos[s],
- rect.x + xpos[s + 1], rect.y + ypos[s + 1]);
+ rect.x + xpos[s], rect.y + (rect.height/2));
if (showPoints)
// Draw points where spacing is enough
That works nicely at some zoom levelsbrian-armstrong wrote:I have made an attempt to show what I mean.
though as you say, it looks a bit strange when there's aliasing at lower zoom levels
and also a bit sparse at maximum zoom
and of course, those vertical lines don't really exist either.
Yes I agree it could be an interesting non-default option, though I think it would need to be tweaked so as to avoid the aliasing.brian-armstrong wrote:Might make an interesting non-default render option
Perhaps bring in the vertical lines only when the dots are show?
(around line 1365 of TrackArtist.cpp)
Code: Select all
if (showPoints)
const int tickSize = bigPoints ? 4 : 3;// Bigger ellipses when draggable.
wxRect pr;
pr.width = tickSize;
pr.height = tickSize;
//different colour when draggable.
dc.SetBrush( bigPoints ? dragsampleBrush : sampleBrush);
if (ypos[s] >= 0 && ypos[s] < rect.height) {
pr.x = rect.x + xpos[s] - tickSize/2;
pr.y = rect.y + ypos[s] - tickSize/2;
dc.DrawEllipse(pr);
// Draw vertical lines
AColor::Line(dc,
else {
// Draw joining lines
// At this zoom level, linear interpolation is generally a reasonable approximation
// of the analog waveform.
AColor::Line(dc,
Just thinking, "Matlab" is a registered trademark, so we may not be able to call such an option "Matlab style samples". Any ideas what this style of graphic representation could be called?
brian-armstrong
Hm, I think that's a good improvement. I do like the stem version at one zoom level up from there, though.steve wrote: Yes I agree it could be an interesting non-default option, though I think it would need to be tweaked so as to avoid the aliasing.
- Attachments
- Screen Shot 2017-02-19 at 4.13.22 PM.png (14.28 KiB) Viewed 1389 times
A related question is: where exactly should the "dot" be located? Should it be at the beginning of the sample period (as now), in the middle, somewhere else, why?
brian-armstrong
I believe these are often called Stem plots.steve wrote:Just thinking, "Matlab" is a registered trademark, so we may not be able to call such an option "Matlab style samples". Any ideas what this style of graphic representation could be called?
https://en.wikibooks.org/wiki/Digital_S ... Stem_Plots
https://www.mathworks.com/help/matlab/ref/stem.html
