Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Trebor
- Operating System: Windows 8 or 8.1
Post
by Trebor » Tue Feb 14, 2017 5:36 pm
If I only use "clip" once then the code works as-expected (symmetrically) on stereo ...
Code: Select all
;version 4
(setq A1 (hzosc 0.090909))
(setq A2 (hzosc 0.052631))
(setq A3 (hzosc 0.034482))
(setq A4 (hzosc 0.024390))
(setq P 0.05) ; Recommend P<0.08
(clip (sim (mult A1 -0.5) (mult A2 -0.5) (mult A3 -0.5) (mult A4 -0.5)
(mult (sum 0.5 (feedback-delay *track* 0.00502512 (* 11 P))) A1)
(mult (sum 0.5 (feedback-delay *track* 0.01492537 (* 3 P))) A2)
(mult (sum 0.5 (feedback-delay *track* 0.02325581 (* 2 P))) A3)
(mult (sum 0.5 (feedback-delay *track* 0.03255813 (* 9 P))) A4)).5)
It's an approximation of the changing acoustic-feedback if the guitarist was moving-about near the loudspeaker
yugioh47
Post
by yugioh47 » Tue Feb 14, 2017 8:41 pm
thanks trebor
<3
