Hi,
Does anyone know how to create a mix of a vocal and audio track, so that when the vocal is active, it dims the volume of the audio track whilst playing?
This is for an internet radio show I am trying to broadcast.
You hear this effect on normal radio shows, where the DJ is talking over some music and the volume dims underneath their voice.
Any tips / suggestions would be much appreciated!
Thank you,
ReggaeBoy
Dim volume under vocal over audio track (for radio show)...
billw58
Re: Dim volume under vocal over audio track (for radio show)
Have a look at this page in the manual. Scroll down to Step 5.
-- Bill
-- Bill
Sounds like a job for AutoDuck.ReggaeBoy wrote:... Does anyone know how to create a mix of a vocal and audio track, so that when the vocal is active, it dims the volume of the audio track whilst playing?
ReggaeBoy
Trebor wrote:Sounds like a job for AutoDuck.ReggaeBoy wrote:... Does anyone know how to create a mix of a vocal and audio track, so that when the vocal is active, it dims the volume of the audio track whilst playing?
Thank you very much, that's the one! -will give this a go.
Paul
ReggaeBoy
billw58 wrote:Have a look at this page in the manual. Scroll down to Step 5.
-- Bill
Thanks Bill,
All very useful. Will try this in association with Autoduck effect.
Best wishes,
Paul
