Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Tue Feb 07, 2017 6:03 pm
Xerlome wrote:I use no wireless at all.
You must make sure you don't press the CTRL key when you click in the blue waves.
Xerlome wrote:A specific question for me is how a project that is playing forward right to left
can be changed to forward left to right.
Normal playback (press the SPACE bar) is always forwards (left to right).
Effect > Reverse used once makes the blue waveform start at what was the end of the audio, like as if you looked at the waveform in a mirror. Normal playback then sounds as if it is playing reversed.
Use Effect > Reverse again to undo the first reverse.
