Dragging/opening files
Help for Audacity on macOS.
Tom Faux
Post by Tom Faux » Mon Jan 09, 2017 2:51 am
All,
In earlier versions I have always been able to drag files into the Audacity window. I am now only able to open files using the menu (Command O). I'm wondering whether it's a bug in my software, an incompatibility, or if there's a setting that I accidentally triggered somewhere. I recently upgraded both my OS and Audacity, so not sure where the problem is.
OSX 10.11.6./Audacity 2.1.2
Thanks.
Tom
Re: Dragging/opening files
Post by kozikowski » Mon Jan 09, 2017 3:57 am
What kind of files specifically? You can also Right-Click > Open With, Control-Click > Open With and File > Import. So there's no shortage of ways to open a sound file.
I can't either, so it may be something that happened in Audacity 2.1.2.
Post by steve » Mon Jan 09, 2017 10:40 am
Tom Faux wrote:In earlier versions I have always been able to drag files into the Audacity window. I am now only able to open files using the menu (Command O). I'm wondering whether it's a bug in my software, an incompatibility, or if there's a setting that I accidentally triggered somewhere. I recently upgraded both my OS and Audacity, so not sure where the problem is.
It's a bug in Audacity 2.1.2. It is fixed in the current development code so the fix will be in Audacity 2.1.3, which will hopefully be released very soon.
Post by Gale Andrews » Mon Jan 09, 2017 4:24 pm
Until then, you can drag most audio file types to the Audacity icon in the Dock, which will do the same as File > Open... .
Tom Faux
Post by Tom Faux » Mon Jan 09, 2017 5:25 pm
Many thanks for the replies, good to know!
Good tip about dragging to the dock.
Tom
Post by kozikowski » Mon Jan 09, 2017 5:38 pm
...writing that down.
Hopefully the same as File > Import.
Post by Gale Andrews » Tue Jan 10, 2017 12:42 am
kozikowski wrote:...writing that down.
No, subsequent files dragged to the Dock will open in new project windows, as far as I know.
