loudness to low
Please state:
ratatouille
Operating System: Linux Debian
loudness to low
Post by ratatouille » Thu Jan 05, 2017 10:15 pm
Hello!
Using openSUSE 13.2
Audacity 2.0.5
Distribution release
I have a zoom H2 and made a fieldrecording. When I listen to it when the SD-Card is put into the zoom, the loudness is ok. As soon as I put the SD-Card into a card-reader on the computer and listen to it with Audacity, the loudness is much lower than in the zoom H2. It is nearly inaudible.
What can be done to get a good loudness with Audacity as with the zoom?
file STE-000.wav
STE-000.wav: RIFF (little-endian) data, WAVE audio, Microsoft PCM, 16 bit, stereo 44100 Hz
Greetings
Andreas
Trebor
Re: loudness to low
Post by Trebor » Fri Jan 06, 2017 4:29 am
ratatouille wrote:...What can be done to get a good loudness with Audacity as with the zoom?
Try moving the playback-volume slider to the right ...
http://manual.audacityteam.org/man/mixer_toolbar.html
ratatouille
Re: loudness to low
Post by ratatouille » Fri Jan 06, 2017 9:03 am
It is already at the most right position. Also I doubleclicked the slider and ajusted the volume furthermore.
But the sound is already low, much lower than when I hear the file frpm within the zoom.
Andreas
Trebor
Re: loudness to low
Post by Trebor » Fri Jan 06, 2017 11:56 am
ratatouille wrote:...But the sound is already low, much lower than when I hear the file frpm within the zoom.
You could amplify the sound to 0dB once it is in Audacity : that should make it louder
Amplify to 0dB in Audacity.png (5.8 KiB) Viewed 453 times
If it's a stereo-recording it's possible for the waveform to cancel-out (destructive interference) if the stereo tracks are converted onto a mono track, (or played through one speaker *) , that cancellation process can reduce volume.
[ * Could be short-circuit in cable connecting headphones to computer making stereo into mono , i.e. try a fresh pair of headphones ].
Re: loudness to low
Post by Gale Andrews » Fri Jan 06, 2017 5:31 pm
Is there some master volume control on the computer that you need to increase? What playback device are you choosing in Audacity?
