Hello,
I've been using Audacity for years. I recently updated my Mac Mini to Sierra (fully updated, 10.12.2) and have also updated Audacity to 2.1.2, downloaded today; this problem existed under 2.1.1 as well. I have also restarted my machine.
I record into Audacity via an Onyx 820i (same as for years). When recording my voiceover, after the update to Sierra (and to 2.1.2), my voice is sped up by 5-10%; when I use the "Change Speed" effect at 95%, it sounds about right.
I have confirmed that the Project Rate is at 44100 Hz, as per usual.
I would welcome any suggestions about what to do. Correcting via the "Change Speed" effect is okay as a short term solution but a bit annoying.
Thanks very much in advance!
Bill Childs
Recording is sped up [SOLVED]
billchilds
Re: Recording is sped up
That sounds about right to be a sample rate mismatch somewhere (44.1 kHz vs 48 kHz).billchilds wrote:my voice is sped up by 5-10%;
Check in the Mac "Audio and MIDI" setup that you are using the same sample rate throughout.
billchilds
Re: Recording is sped up [SOLVED]
That was it! How odd for the input rate for the Onyx to get changed (I certainly didn't go into Audio MIDI) but it was at 48k. Thanks!
