Hey everybody,
I1m using this beta version, and I'm unable to open my saved projects at all. Everytime I save something and try to open it I get the same message:
Error:not well formed(invalid token)in line 171. That is pretty annoying problem, because of this I can't turn off Audacity until I finish a project.
Somebody please help me!
Thanks in advance.
Marton
opening of saved project fails!
Re: opening of saved project fails!
Sometimes you can get this if you put punctuation marks in a filename. Upper and lower case letters, numbers, dash and underline are the only accepted characters. I don't use spaces either.
The point is that I'm using file names like beat2 and so on. So there could be another problem. i'm still needing help.
Unless we can see line 171 of the Audacity ".aup" file we cannot help.
Do you have a text editor that displays line numbers?
If not, try Notepad++ (it's free) http://notepad-plus.sourceforge.net/uk/site.htm
