cutting in Audacity [SOLVED]
jukeboxjackson
Post by jukeboxjackson » Fri Dec 30, 2016 5:07 pm
My curser won't let me highlight required parts of a song to edit/cut
I'm in stop mode but when I choose a particular part of a song to edit, the 'line' moves to another part.
Can anyone help, please?
Re: cutting in Audacity
Post by steve » Fri Dec 30, 2016 5:27 pm
Check that you haven't accidentally enabled "Snap To" http://manual.audacityteam.org/man/sele ... .html#snap
jukeboxjackson
Re: cutting in Audacity [SOLVED]
Post by jukeboxjackson » Fri Dec 30, 2016 6:02 pm
Wow!! Thanks so much - 'Snap to' was on 'nearest', changed to 'off' - working great now
