Keyboard combinations
Re: Keyboard combinations
I'm also doing it on Sierra, and the only problem I have is that it doesn't appear until you type in the character the diacritic is to be applied to, not that you have to type it in twice. That should be good enough if you find you have serious problems in getting it to work exactly right; it really isn't a big deal if it doesn't appear beforehand if you do.
Although now I see what you mean, but as I said, it really isn't a big deal if it doesn't appear beforehand.
This hasn't been fixed, and it doesn't appear in the release notes, are you still working on it?
billw58
Thanks for following up on this. As far as I can tell this was never logged as a bug. I'll do that now.
-- Bill
-- Bill
