No sound through headphones
Please state:
Please state:
I am running Ubuntu 14.04
I have a Focusrite Scarlett 2i2 interface connected to my computer.
I can hear my bass through the headphones, through the 2i2.
I cannot hear the Audacity playback through the headphones.
Re: No sound through headphones
That's your live instrument?I can hear my bass through the headphones
Can you play an Audacity sound into your 2i2 without overdubbing? If you are Overdubbing, you should select Audacity > Preferences > Recording > [X] overdubbing > OK.
If you can't ever play Audacity into your 2i2, then you have to select the 2i2 in your Audacity Device Toolbar.
http://manual.audacityteam.org/man/device_toolbar.html
And that's where you lose me since I'm not a Linux elf.
Thanks for the reply Koz,
Yes, I'm using a bass guitar. I neglected to be clear about that.
I am not able to run Audacity through the 2i2 with or without overdubbing.
I did try selecting the 2i2, in Audacity.
Audacity still does not play through the headphones.
This is where you have to get the Linux systems to help you and it's the exact place I go hide in the corner.
- Quality Assurance
With the 2i2 explicitly chosen as Playback Device in Device Toolbar, ensure that the Audacity playback volume is turned up (speaker symbol) in Mixer Toolbar:PartTime wrote:I am not able to run Audacity through the 2i2 with or without overdubbing.
If that does not help, please post the complete information from Help > Audio Device Info... top right of Audacity.
Thanks for the reply Gale.
Here is the message I got: Stream is active ... unable to gather information.
- Quality Assurance
Press the yellow Stop button, then try Help > Audio Device Info... again.PartTime wrote:Here is the message I got: Stream is active ... unable to gather information.
Have you tried turning up the playback volume in Mixer Toolbar?
What version of Audacity are you using? Give us all three numbers from Help > About Audacity... .
I pressed the yellow stop button before going into help. That didn't do anything.
I neglected to mention that I did turn up the slider.
The version that I'm using is; 2.0.5
After trying the suggestion, I still get the same message: Stream is active ... unable to gather information.
It could be that you have clicked on the recording meter and activated the meter (and so started an audio stream).PartTime wrote:After trying the suggestion, I still get the same message: Stream is active ... unable to gather information.
Try clicking on the recording meter to stop monitoring, then try Help > Audio Device Info... again.
If that does not work, shut down Audacity entirely, then relaunch Audacity and do "Help > Audio Device Info..." (taking care to not click or type anything else).
