Compared to the version of yours you liked from Koz I'ld say the only difference is the low end of vocal has been EQ'ed downward maybe tapering off starting around 300hz. You'll have to experiment.Zero101 wrote:Also could you help me sound like this please. The thing i like about this video is that his audio is so clear.kozikowski wrote:I have to post the steps how I did it. I tried to make it more firm and louder without damage or changing the natural quality of your voice.New-Raw-Audio-volume-patched.wav
But I need to go back to my notes how I did it.
Video - https://www.youtube.com/watch?v=2OTAaMxY19o
I need help with my Audio
Tim Lookingbill
- Operating System: OS X 10.6 Snow Leopard or earlier
Re: I need help with my Audio
Probably not. He has different natural voice pitch than you do. Most of the quality is the same between the two performances. I think you should go with these simple corrections for a while and get used to producing the video.Also could you help me sound like this please.
I applied a custom loudness tool from Steve called SetRMS. It's a Nyquist program. It's a paragraph of almost English words which you can copy and paste in Effect > Nyquist Prompt. It automatically sets the overall volume of the show (or whatever you select) and doesn't care if some of the blue waves get too high. Scroll down to where it says "You can get SetRMS from me."
http://forum.audacityteam.org/viewtopic ... 84#p318684
Then I ran Effect > Limiter with these settings.
Try those two on a longer performance. Try around 20 minutes or so. SetRMS was designed for audiobooks, but it should work just fine for you. If your voice changes volume too much, the finished segment may sound a little funny, but if you manage to stay even, it should sound OK.
I'm composing some of this as we go, so post back if you can't follow a step.
- Attachments
- Screen Shot 2016-12-29 at 17.38.34.png (105.32 KiB) Viewed 248 times
