Can't change sample rate on export!?
I'm working with an 8 bit/11K mono .wav file that I would like to export as a 16bit/44K mono .wav, but I can't get Audacity to do this for me. I've changed the project rate at the bottom left to 44.1 and used the mono tracks' drop-down to reset the rate but it still exports incorrectly. When I get the file into luna it's still playing the file at the old sample rate speed.
I must be doing something wrong. Can anyone break it down for me as to how this can be done?
Dual 1.4 processor G4 w. 1.25GB RAM
Tiger 10.4.11
Pro Tools LE 7.3, Audacity 1.2.6 stable, MuLab Free
Live Lite 6, Reason Adapted 3.0
hp Media center pc 873n Intel Pentium 4, 2.53.GHz.
Audacity 1.2 stable
Nec Asperra Terrent
Tiger 10.4.11
Audacity 1.2 stable
Nec Asperra Terrent
Re: Can't change sample rate on export!?
Audacity isn't a very good program for standards conversion IMHO. I would be doing this in QuickTime Pro($). Simple Import/Export. Other Windows programs may apply. I don't know of any free ones.
