Trebor wrote: ↑Tue Feb 13, 2018 9:41 pm
it's the equalizer GUI which takes too long to appear once selected from the menu,
I do find that some GUI effects are sometimes slow to open on Windows 10, but this is not specific to the Equalization effect.
When testing 5 minutes ago with Audacity 2.3.0, Equalization opened in about half a second, but PaulStretch tool close to 3 seconds to open.
I then tested with Audacity 2.2.2, and both Equalization and PaulStretch opened withing half a second.
I then retested with Audacity 2.3.0, and both Equalization and PaulStretch opened within half a second.
Perhaps Windows was busy doing something in the background when I tested first time (?)
Opening effects on Windows (Audacity 2.2.2 and 2.3.0 and 2.3.1) definitely feels sluggish compared to Xubuntu, but perhaps that is just Windows. I don't see any repeatable regression in this respect.
Update: Testing with Audacity 2.1.3, I sometimes see GUI effects taking a couple of seconds to open. This is not reliably repeatable - sometimes it happens, sometimes it doesn't, as is the case with later versions of Audacity.
