"faulty sequence tags" and shifted stereo channels
Help for Audacity on macOS.
platypus67
Post by platypus67 » Wed Nov 30, 2016 4:54 pm
Audacity 2.1.2, dmg installer, OS 10.9.5
Using Audacity to edit recordings made on a Tascam unit, 96k stereo WAV files. Everything worked great during the editing (lots of cut/paste from different source files, basically an exercise CD for a translation text book, with dialogues etc.); toward the end I checked dependencies and copied files because it says that's "safest". But today as I reopen the projects, I get messages about "faulty sequence tags" and also block orphans; the programs claims it can recover the files, so I let it. Looks good at first glance, but it turns out parts (but not all) of the tracks have shifted left/right channels around (no longer in sync, garbled with audio from elsewhere in the original file :shock: ) so the whole edit is useless. I can only surmise that something went wrong during the file copy, but I really don't understand how, unless there is an issue with WAV files from Tascam. Why would left/right channel go out of sync, never having been split, and only on some cuts from the source material, which hasn't been touched either? I get the error message(s) on every one of three saved projects that I've worked on so far and that were fine until I closed the program down for the night. :cry:
I haven't been able to find anything like this happening to anyone else. Any thoughts at all? Should I go back to an older version? Work from originals again? I'm on a deadline so I need to figure out a reliable work-around. Obviously I'll now be exporting a backup WAV at the end of the day, but this is really not optimal if I'm not done with the edit.
I'm wondering if there is something wrong with my work flow. I load the source track(s) into Audacity, create a new project, cut/paste into it, then as I get done with each source I close it again (at which point I am asked if I want to save the project, which I don't, since it's only a window with the source track; I do of course frequently save the actual project with the edit).
Does any of that make sense? Cheers.
Re: "faulty sequence tags" and shifted stereo channels
Post by kozikowski » Wed Nov 30, 2016 5:42 pm
Project work is saved as a cloud of tiny .au files, and they alternate left-right. So I'm not shocked that an unstable system could reverse left and right by accident. But it seems your system is just garden-hosing files around at random.
The "safer" thing is just Audacity making personal, internal copies of all your external music and sound files. If you don't do that, you will not be able to move your project.
I personally would be checking my drive health. Go > Utilities > Disk Utilities. I think 10.9 still had a Disk Check or something like that.
platypus67
Post by platypus67 » Wed Nov 30, 2016 6:45 pm
Thank you for the quick response and suggestion. I will do more tests on the drive, but since my laptop is otherwise functioning flawlessly, I doubt there is a hardware issue. However, you are probably correct about the AU files getting mixed up somehow. To clarify (hopefully), I'm attaching a couple of screen shots of a track, with the offsets highlighted. Both channels ought to look the same (as they do in the source file), since the mic was mono. In one case, the right channel seems to have been replaced with sound from somewhere else in the file. In the other, a small segment (orange highlight) has been replaced with something else, shifting the rest of the channel within the clip to the left (but not affecting the next clip, where everything is back to normal, for a few seconds). I had hoped that maybe only the right channel was affected, but while there are more issues than in the left, the left is also affected so that I can't just delete one of the channels and keep the other. It is baffling. There was no crash with all of the affected projects open or anything like that.
examples of out-of-sync channels
Screen Shot 2016-11-30 at 19.32.08.jpg (240.07 KiB) Viewed 745 times
Post by kozikowski » Wed Nov 30, 2016 8:37 pm
As far as you know. The video people run into this. Video and audio production are in the short list of applications that stress a machine. You don't need extended memory to write a letter to your mum or check your email.
If everything is truly scrambled, you can reset Audacity. Reinstalling Audacity doesn't reset it. Audacity keeps preferences and settings separate to make updates easier. They're sticky.
Close Audacity.
Go > Go To Folder > ~/Library. Open Application Support. Drag the audacity folder to the trash. The next time you start Audacity, it will arrive at First Birthday with no settings or preferences. And it may have lost its bad habits.
Do you have a current list of add-ons and plugins? That's going to vanish, too. If you need to save those, that's harder and I have to look that one up.
In Disk Utilities, the tool is "Verify Disk." On newer Macs that has been changed to 'Just fix it and call me if you have a problem.' I'm not crazy about that in a diagnostic tool.
And just to cover it, do you get your cheerful 'Chong' when you restart the Mac? Do you ever restart your Mac?
Post by kozikowski » Wed Nov 30, 2016 8:50 pm
Close Audacity.
Go > Go To Folder > ~/Library. Open Application Support > audacity. Drag audacity.cfg to the trash.
This is not a burn it off solution. If you have a bad plugin or add-on, it will still be there when you reopen Audacity.
platypus67
Post by platypus67 » Thu Dec 01, 2016 12:06 pm
Thank you for the further suggestions :) . There are no plug-ins/add-ons apart from the Lame & ffmpeg libraries, so I shall ditch the settings folder in case (e.g.) there are some weird leftovers from a previous version. The drive verified fine but I also ran a permissions fix just in case, which was long overdue. I shall create a project with the default settings and see what happens. Fingers crossed.
Post by Gale Andrews » Thu Dec 01, 2016 1:13 pm
Were these projects originally created in 2.1.2, or in some older 1.2 version of Audacity? The latter would be more understandable.
If it happens again, please post the log from Help > Show Log... so we can see the errors.
If you want a mono file as a result of your work, it might be best to paste into a mono track (select the track and do Tracks > Stereo Track to Mono). There is a bug in 2.1.2 with pasting mono into stereo which will be fixed for the next 2.1.3 release when that arrives. However the problem should be visible immediately.
If you want to try 2.1.3-alpha (it's fairly stable now) you can get it from the topmost folder on http://www.audacity.homerow.net/index.php?dir=mac/.
platypus67
Post by platypus67 » Thu Dec 01, 2016 10:10 pm
Hi Gale, thank you. The projects were created in 2.1.2. The .wav files have two channels by default, so even though the left & right are the same they ought to be recognised as stereo. I haven't tried 2.1.3 yet; however, today I did delete my preferences (etc.) folder, rebooted, and started afresh with one of the projects. After editing together the tracks and saving the project, I quit audacity and then reopened by loading the project file. Got the message, "project check... detected 32 missing alias (.auf) blockfiles." I let audacity "regenerate alias summary files," saved, quit, opened again; now the project seems to be fine. So far no dislocations.
Am I getting this messages because of the wacky way I'm editing? I don't know how else to do it since there's no hold-all folder within the program for all the source files, such as in Final Cut, say. So I load each source into audacity, which of course creates a project window for it; then I copy whatever I need, paste it into my actual project, and when I'm done with the source file I close that window without saving (I don't need a project file for my raw material...). Is there a better (or correct) way of doing this that I'm missing? Possibly these are two different issues.
I will try to take the time also to do some work on this using another computer tomorrow, just to make sure it's not the hardware or OS on this machine.
Cheers.
Post by kozikowski » Fri Dec 02, 2016 6:06 am
Right. That also means we can't tell you Clip Info. When work comes into Audacity, it loses all its original personality (except sound quality). Even worse, Audacity works at 32-bit floating internally to make effects and filters seamless, so the sound is even further away from its original format.
platypus67
Post by platypus67 » Fri Dec 02, 2016 9:26 am
Hi Koz, I'm not complaining at all about audacity's inner workings, just trying to establish whether my workflow is at fault or there is a better way of editing multiple clips together. It's been a while since I've used audacity, but I've never had any issues with file integrity, so I'm a bit freaked out since I have to assemble 17 chapters of dialogues and exercises by Dec. 10. Of course it would be useful to be able to trace a clip back to its source file (in that case I might have been able to repair the original damage) but I'll trade that for the flexibility I'm getting in audio manipulation, as long as I can rely on the internal workings not to let me down. That's not too much to ask now is it (i.e. spare the sarcasm please ;) ). I've read through the release notes and it sounds a bit like the "Bug:137" listed under "Moonphase." If I can replicate the error (I hope not...) I will upload the log, but it really doesn't say much except that it can't find the files on the first reopen after saving the project and exiting. Furthermore there is a note that "Left-clicking in a stereo track to merge a clip at a split line may cause other clips to move" and I'm wondering whether that inadvertently happened before when the content shifted (even though I did not do any mono->stereo conversion).
I made a quick test edit on my other system, an older iMac, OS 10.11.6, same audacity build (2.1.2 release), and I'm not having any issues except for extreme sluggishness after about the 5th edit (which is why I would prefer not to edit on this system). It's not quite identical since the ffmpeg library is not installed and I'm loading the source off a network drive rather than the local HD (and yet, no lost files...). Hm. Here's another random thought (grasping at straws): on the macbook pro the projects are in a subdirectory under the .wav files. idk. :? Should I upgrade (the macbook) to Sierra or would that invite more issues than it might solve?
