Most numbers won't show up [SOLVED]
Please state:
thejman0205
Post by thejman0205 » Sat Nov 19, 2016 8:33 pm
I'm using Audacity 2.1.2 on Ubuntu 16.04 LTS. In some places, the numbers show up like normal, like in some parts of effect and generate windows. I've tried uninstalling and reinstalling with apt, but it hasn't worked.
Re: Most numbers won't show up
Post by steve » Sun Nov 20, 2016 1:10 pm
What is the system language on your computer?
Have you set a specific language in Audacity preferences or are you using the default?
thejman0205
Post by thejman0205 » Sun Nov 20, 2016 5:24 pm
I'm using US English on my computer and the default on Audacity. I tried changing it to English to see if anything changed, but nothing did.
Post by Gale Andrews » Mon Nov 21, 2016 2:50 pm
Where did 2.1.2 come from? How did you install it? I don't see anything on the Ubuntu bug tracker https://bugs.launchpad.net/ubuntu/?fiel ... t=audacity about this, so perhaps it is specific to your computer.
Have you installed open source graphics drivers? These can cause issues.
thejman0205
Post by thejman0205 » Sat Nov 26, 2016 3:08 pm
I found a solution. I recently installed a color emoji font, and if I disable it, the numbers show up like normal. I still don't know why it was causing problems, though.
Re: Most numbers won't show up [SOLVED]
Post by Gale Andrews » Sun Nov 27, 2016 3:09 pm
Thanks for saying what fixed it. So I will mark the topic as "[SOLVED]" and lock it.
