Thanks Trebor!Trebor wrote:If you're trying to record the sound playing on the computer, try selecting "WASAPI" in Audacity Preferences, "Devices" ...Gunns wrote:... I'm recording music from a web site that is played through my computer straight into the Audacity program. So the only equipment that is involved is my computer. This has worked perfectly for quite a while. Then all of a sudden the error started popping up.
Before reading your post I tried using Audicity one more time and it was working perfectly as it was in the past. Didn't change anything but now it's appears to be working just fine. I checked the "preferences/devices" as you suggested. Mine was set as "MME". What's the difference between the two (MME and WASAPI)?
