Boom2Device
Boom2Device
My playback device is coming up as Boom2Device. I have Boom as an EQ for my computer speakers but do not use it through my monitors. How do I delete this as a playback device?
- Quality Assurance
Re: Boom2Device
Audacity cannot control this. If you cannot configure which playback devices Boom works with, then your only option is to remove the kernel extension to completely uninstall it. See http://superuser.com/a/969814.David B wrote:My playback device is coming up as Boom2Device. I have Boom as an EQ for my computer speakers but do not use it through my monitors. How do I delete this as a playback device?
Re: Boom2Device
Sound Control doesn't have this problem...
