Let us be clear. Audacity as shipped does not support ASIO or ASIO4ALL. You would have to install Visual Studio, the ASIO SDK, then wxWidgets then compile the Audacity source code. See http://wiki.audacityteam.org/wiki/ASIO_ ... io_support.
I assume you don't want all that.
Audacity recording meter problem
- Quality Assurance
Re: Audacity recording meter problem
