hi
at what setting should the recording volume slider be set?its at 55% now?
benbernie
- Quality Assurance
Re: the recording volume
No specific value - it depends on the input you are using and the strength of the input signal.
Adjust the recording level so that the loudest parts do not go above -6 dB on the recording meters.
thanks
