output sound volume
Help for Audacity on macOS.
Re: output sound volume
Post by Gale Andrews » Wed Oct 12, 2016 11:25 pm
rtomasov wrote:Don't you believe it could help your reading the .cfg file?
Already answered. You posted the Audio Device Info which I asked for, which lets us see all your audio devices. The audacity.cfg file has much less information of relevance.
I understand you deleted audacity.cfg which would make all your settings default, and the problem continued. We know what the defaults are.
rtomasov wrote:You would need to tell me how to upload it.
Already answered. It just needs renaming to "audacity.txt" (without quotes) then attached as you attached the Audio Device Info.
rtomasov
Operating System: OS X 10.10 Yosemite
Post by rtomasov » Thu Oct 13, 2016 8:14 am
Some news: sound output selection and volume went back to normal after uninstalling Soundflower.
Regarding uploading the .cfg file, a .txt file would not be allowed; I've tried it, see screenshot.
Thank you,
Ruben
Screen shot 2016-10-13 at 10.11.37.jpg (19.97 KiB) Viewed 725 times
Post by Gale Andrews » Thu Oct 13, 2016 1:45 pm
rtomasov wrote:Some news: sound output selection and volume went back to normal after uninstalling Soundflower.
If you need Soundflower you could try reinstalling it. At least you know that uninstalling it again would solve any problems it creates.
rtomasov wrote:Regarding uploading the .cfg file, a .txt file would not be allowed; I've tried it, see screenshot.
As explained previously, don't put quotes round the extension. It works with .txt extension, even on Mac.
rtomasov
Post by rtomasov » Fri Oct 14, 2016 8:16 pm
rtomasov wrote:
Gale Andrews wrote:
rtomasov wrote:
Gale Andrews wrote:You could uninstall and reintstall Soundflower for sure. In the /Applications/Soundflower/ folder, double-click "Uninstall Soundflower.scpt". In the window that opens, press the "Run" button. You should see "Done!" in the results, indicating that the uninstallation completed satisfactorily.
What would uninstalling sunflower do?
I don't believe sunflower is the culprit.
Nobody has a rational explanation for what is happening so you may have to think a little outside the box.
Soundflower is a kernel extension so has considerable scope to make system changes. We don't even know which version of Soundflower you have or whether it is appropriate for Snow Leopard. Early versions of Soundflower were very buggy.
It worked.
Thanks Gale
Ruben
rtomasov
Post by rtomasov » Tue Dec 13, 2016 6:05 pm
Gale Andrews wrote:
rtomasov wrote:
I still prefer OS X 10.6.8 and would not give it up until I'm forced to buy a new Mac.
Gale Andrews wrote:Audacity will sooner or later drop support for OS X 10.6 because it impedes developing Audacity for current macOS. It will happen as soon as we fix enough bugs to make a good "final version" for Snow Leopard.
Hello Gale,
It's been a long time since my latest post and many things have happened.
1-The Sennheiser USB headphones I’ve sent for repair were sent back to me in a new package; no reason was given but, they must have been malfunctioning.
They sounded fine when I first tried them, sound volume was OK.
Then they stopped sounding well; the sound volume is about 50% or less than the sound volume one gets from the internal speakers using a plugged-in standard headphone.
The only difference from what I’ve written on my first post is, I don’t need to select the output device in Audacity in order to listen through a different device selected in System Prefs.
2-I’ve taken the big step and upgraded to macOS X 10.11.6 El Capitan.
The upgrading has had no effect on the output sound volume when listening through the Sennheiser headphones.
I have twice repeated the procedure you or Cyrano have suggested deleting the .plist in /Library/Preferences/Audio but to no effect.
I’ve written to Sennheiser about a week ago telling them about the persisting problem with their headphones but have not gotten any reply yet.
Can only hope to get more help from you if at all possible.
Thank you an best regards,
Ruben
Post by Gale Andrews » Wed Dec 14, 2016 4:34 pm
Sorry but I cannot fix your headphones or make them compatible with Mac. The Apple forums might have some further ideas of things you can try. They may suggest resetting the SMC.
rtomasov
Post by rtomasov » Wed Dec 14, 2016 5:02 pm
Sorry but I cannot fix your headphones or make them compatible with Mac. The Apple forums might have some further ideas of things you can try. They may suggest resetting the SMC. Gale
I've posted the issue on the Apple forums but never got a reply.
As to resetting the SMC, this function doesn't address the issue.
Thanks
Post by Gale Andrews » Wed Dec 14, 2016 5:09 pm
Does rebooting the Mac enable the headphones to work at full volume again, at least for a while?
rtomasov
Post by rtomasov » Wed Dec 14, 2016 6:36 pm
No, it doesn't
cyrano
Post by cyrano » Wed Dec 14, 2016 8:22 pm
Have you tried zapping the pram? Hold down option-command-p-r right after the startup sound to do so...
