output sound volume
Re: output sound volume
I'm beginning to wonder if it's not time to do a clean install of Snow...
Something is reproducing the error in the plist files. That's like wrestling a bear. Could it be Soundflower? Any chance there's a leftover from a JackOSX install?
- Quality Assurance
You could uninstall and reinstall Soundflower for sure. In the /Applications/Soundflower/ folder, double-click "Uninstall Soundflower.scpt". In the window that opens, press the "Run" button. You should see "Done!" in the results, indicating that the uninstallation completed satisfactorily.
GaleGale Andrews wrote:So does the problem only start after the plist files are recreated? It's a thin chance, but it might be possible to edit the plist files. You would not do that in TextEdit though.rtomasov wrote:Yes, I do.Gale Andrews wrote: Do you still have to select the USB headset in Audacity before the headset can be heard at all in other applications?
You could perhaps repeat the plist file deletions then reboot, then observe if the problem only starts after the plist files are recreated.
Now (today), I don't have to select the USB headset in Audacity before the headset can be heard in other applications.
Can't tell why it is now correct.
BTW, do you remember I couldn't upload the .cfg file either in .rtf or in .cfg format?
Just tried to upload it as a .txt file but it is not accepted either.
Maybe you could tell me how to edit the plist files if necessary.
It is a pity you cannot read the .cfg file; I believe it would help you on knowing what's happening.
I don't know which kind of file can be uploaded.
Thank you
What would uninstalling sunflower do?Gale Andrews wrote:You could uninstall and reinstall Soundflower for sure. In the /Applications/Soundflower/ folder, double-click "Uninstall Soundflower.scpt". In the window that opens, press the "Run" button. You should see "Done!" in the results, indicating that the uninstallation completed satisfactorily.
I don't believe sunflower is the culprit.
Please read my latest reply to you about 5 minutes ago.
Thanks
Please read my latest reply to Gale Andrews.cyrano wrote:I'm beginning to wonder if it's not time to do a clean install of Snow...
I don't believe soundflower is the culprit.
I've just been able (today, 15 minutes ago) to listen through the headset and through the internal speakers without having to go to Audacity to change the output.
I've done a clean install of OSX 10.6.8 a couple of weeks ago.
What is a JackOSX install?
Thanks
Jack is a Linux audio router, just like SoundFlower. Often, people who have installed SoundFlower have tried JackOSX or one of the other versions for Mac before. Removing it correctly is not always easy for most users.
Having both SoundFlower and Jack is a sure way to trouble.
But as you have a clean install from a few weeks ago and never heard about Jack, that's not the reason why you have this strange error...
And, I don't have JackOSX!cyrano wrote:Jack is a Linux audio router, just like SoundFlower. Often, people who have installed SoundFlower have tried JackOSX or one of the other versions for Mac before. Removing it correctly is not always easy for most users
- Quality Assurance
Nobody has a rational explanation for what is happening so you may have to think a little outside the box.rtomasov wrote:What would uninstalling sunflower do?Gale Andrews wrote:You could uninstall and reintstall Soundflower for sure. In the /Applications/Soundflower/ folder, double-click "Uninstall Soundflower.scpt". In the window that opens, press the "Run" button. You should see "Done!" in the results, indicating that the uninstallation completed satisfactorily.
Soundflower is a kernel extension so has considerable scope to make system changes. We don't even know which version of Soundflower you have or whether it is appropriate for Snow Leopard. Early versions of Soundflower were very buggy.
- Quality Assurance
Well you could open Finder and check if the plist files you deleted have been recreated.rtomasov wrote:Now (today), I don't have to select the USB headset in Audacity before the headset can be heard in other applications.Gale Andrews wrote:So does the problem only start after the plist files are recreated? It's a thin chance, but it might be possible to edit the plist files. You would not do that in TextEdit though.rtomasov wrote:Yes, I do.Gale Andrews wrote: Do you still have to select the USB headset in Audacity before the headset can be heard at all in other applications?
If they have been recreated, you can copy them to your Desktop in case they come in handy.
Text files are allowed if they have .txt extension. Files with .cfg extension cannot be allowed for security reasons. If you ever want to post audacity.cfg, make a copy and rename it in Finder to audacity.txt.rtomasov wrote:BTW, do you remember I couldn't upload the .cfg file either in .rtf or in .cfg format?
I see no strong reason to disallow .rtf extension so I have enabled it.
TextWrangler would work, as the plist files are XML rather than binary. Let's go into that only if we need to.rtomasov wrote:Maybe you could tell me how to edit the plist files if necessary.
It would not help with the strange audio problem that seemingly you alone are having.rtomasov wrote:It is a pity you cannot read the .cfg file; I believe it would help you on knowing what's happening.
Soundflower is v1.6.6b which I've got from Audacity's website.Gale Andrews wrote:Nobody has a rational explanation for what is happening so you may have to think a little outside the box.rtomasov wrote:What would uninstalling sunflower do?Gale Andrews wrote:You could uninstall and reintstall Soundflower for sure. In the /Applications/Soundflower/ folder, double-click "Uninstall Soundflower.scpt". In the window that opens, press the "Run" button. You should see "Done!" in the results, indicating that the uninstallation completed satisfactorily.
OK, I'll uninstall it and see what happens. Will let you know.
Don't you believe it could help your reading the .cfg file?
You would need to tell me how to upload it.
Thank you
