Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
rtomasov
- Operating System: OS X 10.10 Yosemite
Post
by rtomasov » Sat Oct 08, 2016 3:20 pm
Tried it, no difference at all.
What's happening to Audacity, has it gone bilingual?
This build is in Spanish which I know but it makes me feel schizo. I prefer to have everything in English so as not to be forced to switch to a different language.
Gale Andrews wrote:Audacity will sooner or later drop support for OS X 10.6 because it impedes developing Audacity for current macOS. It will happen as soon as we fix enough bugs to make a good "final version" for Snow Leopard.
A pity!
- Quality Assurance
Post
by Gale Andrews » Sat Oct 08, 2016 4:32 pm
The build is language-independent. If you have the Mac running in Spanish then Audacity defaults to Spanish.
You can choose the language you want at Audacity > Preferences..., "Interface" section.
rtomasov
Post
by rtomasov » Sat Oct 08, 2016 5:01 pm
Gale Andrews wrote:rtomasov wrote:
rtomasov wrote:Tried it, no difference at all.
Gale Andrews wrote:The build is language-independent. If you have the Mac running in Spanish then Audacity defaults to Spanish.
My Mac
is not running in Spanish; I don't understand why this build opened in Spanish.
In any case, I don't see your comment on "
Tried it, no difference at all."
Where do I go from here?
Thanks
- Quality Assurance
Post
by Gale Andrews » Sun Oct 09, 2016 4:54 pm
rtomasov wrote:I don't see your comment on "Tried it, no difference at all."
Nothing can be fixed until we can reproduce the problem. No-one else has the problem that you are experiencing and no-one here has a working installation of Snow Leopard. Apple dropped support for Snow Leopard over two years ago. And even so, no-one reported this problem when Snow Leopard was in Apple support.
Can you still run Mavericks on the external drive you mentioned? Does Mavericks exhibit the problem?
Also you can look at
http://www.audacityteam.org/download/legacy-mac/. There is an older 2.0.6 version of Audacity you can try, or older 2.0.x versions if you click the GoogleCode link farther down that page.
cyrano
Post
by cyrano » Sun Oct 09, 2016 8:18 pm
rtomasov wrote:What's happening to Audacity, has it gone bilingual?
I've had this error with Audacity too, under Snow. It's been a while and I can't remember exactly how I solved this. And it probably was an older Audacity version too.
Did you delete some languages from your Mac?
Did you try resetting system language to English in System Prefrences-> Language & Text?
Did you try SL-NTFS (a Windows utility enabling use of NTFS disks) or anything likewise?
BTW I don't think this is an Audacity error, as it seems to happen to a lot of applications in rare cases.
rtomasov
Post
by rtomasov » Mon Oct 10, 2016 7:49 pm
cyrano wrote:rtomasov wrote:What's happening to Audacity, has it gone bilingual?
Haven't deleted any language.
cyrano wrote: Did you try resetting system language to English in System Prefrences-> Language & Text?
Language & Text in System Preferences is set to English.
Didn't try SL-NTFS
This issye happened only in Audaccity.
Thanks
rtomasov
Post
by rtomasov » Mon Oct 10, 2016 7:59 pm
Gale Andrews wrote:rtomasov wrote:I don't see your comment on "Tried it, no difference at all."
The problem doesn't happen in Mavericks, i wonder why. The computer is one; Mavericks is installed on an external HD but the Mac is controlling it. Baffling since the headset has no driver; it's a plug and play set.
Thank you Gale
cyrano
Post
by cyrano » Mon Oct 10, 2016 9:32 pm
Sometimes Core Audio prefs get corrupt and you need to trash them. Give this a try:
- Go to ~/Library/Preferences/Audio
- Delete com.apple.audio.DeviceSettings.plist
- Delete com.apple.audio.SystemSettings.plist
- Restart your Mac
rtomasov
Post
by rtomasov » Tue Oct 11, 2016 9:46 am
cyrano wrote:Sometimes Core Audio prefs get corrupt and you need to trash them. Give this a try:
- Restart your Mac
cyrano,
There is no Audio folder in ~/Library/Preferences.
Do you mean /Library/Preferences?
I find
com.apple.audio.DeviceSettings.plist & com.apple.audio.SystemSettings.plist in
Thanks
cyrano
Post
by cyrano » Tue Oct 11, 2016 11:41 am
Yes. Sorry, brainfart.
