Click on timeline plays selection if time unit is seconds
DickN
Post by DickN » Tue Oct 04, 2016 3:57 am
If the time unit is set to "seconds" and snap is set to "Nearest" or "Prior", clicking on the timeline anywhere except very close to a whole second plays the selection (or from the select cursor) instead of from the mouse cursor location on the timeline. I did get it to play from the mouse cursor location a few times from very nearly an exact half-second.
The zoom is as set by Ctrl-2.
OS: Windows Vista Home Premium SP2;
Audacity version: 2.1.2 or 2.1.3 Alpha Apr 28 2016. 2.1.3 is from the zip; I can't say whether 2.1.2 is from the zip or the installer.
- DickN
Re: Click on timeline plays selection if time unit is second
Post by steve » Tue Oct 04, 2016 7:17 am
DickN wrote:If the time unit is set to "seconds" and snap is set to "Nearest" or "Prior", clicking on the timeline anywhere except very close to a whole second plays the selection (or from the select cursor) instead of from the mouse cursor location on the timeline.
That's the correct.
The Play position is indicated by a vertical line over the tracks, which should be yellow rather than the usual white colour, to indicate that it is "snapped" to a time location.
Post by Gale Andrews » Tue Oct 04, 2016 12:52 pm
DickN wrote:If the time unit is set to "seconds" and snap is set to "Nearest" or "Prior", clicking on the timeline anywhere except very close to a whole second plays the selection (or from the select cursor) instead of from the mouse cursor location on the timeline. I did get it to play from the mouse cursor location a few times from very nearly an exact half-second.
Thanks, Dick. Yes very occasionally it will play from the Timeline click position but generally not. Bug added http://bugzilla.audacityteam.org/show_bug.cgi?id=1520.
