Is it possible to separate out piano accompaniment from a recording with violin and piano with Audacity? I want to 'extract' out just the violin part, and perhaps do some synthesis to the violin part only.
Thanks
I want to separate out the piano accompaniment part
walter1688
Re: I want to separate out the piano accompaniment part
As a fuzzy rule Audacity can't split a mixed performance into individual instruments or voices.
You can try Effect > Vocal Removal and Isolation. It's designed for voices, but sometimes you can get lucky.
http://manual.audacityteam.org/man/voca ... ation.html
