no line in
benbernie
no line in
Post by benbernie » Fri Sep 30, 2016 2:04 pm
hi
when I open up audacity Ithese is no line in ir speakers in the little windows at the top.this might be a computer problem but maybe you can give me an idea..thanks
lenny
DVDdoug
Forum Crew
Re: no line in
Post by DVDdoug » Fri Sep 30, 2016 2:28 pm
Does your computer have a line-in connection (usually blue on your soundcard)?
...[o]r speakers
Does anything show-up as a Playback Device?
If you have a laptop, you probably have only mono microphone-in and headphone-out and you'll need to use a USB audio interface with line inputs. Don't get a regular "USB Soundcard" because they are like laptops with only mic-in and headphone-out. (The Behringer UCA202 is popular and inexpensive.)
benbernie
Re: no line in
Post by benbernie » Fri Sep 30, 2016 2:47 pm
yeah theres a line in on my sound card I believe I put the wire in but it didn't list anything..its a regular desk top..
lenny
DVDdoug
Forum Crew
Re: no line in
Post by DVDdoug » Fri Sep 30, 2016 3:00 pm
Right click on the Windows speaker icon, then select Recording Devices and check to see if it shows Line-In and that it's enabled.
If Windows sees it, Audacity should see it. You may have to plug something in to "wake-up" the line input before starting Audacity.
If windows isn't seeing it, you may have a driver problem.
benbernie
Re: no line in
Post by benbernie » Fri Sep 30, 2016 3:56 pm
nevermind thanks
Re: no line in
Post by steve » Fri Sep 30, 2016 4:08 pm
benbernie wrote:nevermind thanks
Is the problem solved?
What solved it?
benbernie
Re: no line in
Post by benbernie » Fri Sep 30, 2016 4:27 pm
hi the problem is still unsolved..when I went into the line it it said its "not plugged in"when I tried to plug it in it still didn't work..i only so much patience for this stuff..
