cant hear playback it is very low
ESTEE
Post by ESTEE » Sat Sep 24, 2016 11:49 am
all of a sudden it is low. then it was ok - cant tell how it was fixed. then again now impossible to hear it is so low and quiet
pls help
thank you
Re: cant hear playback it is very low
Post by Gale Andrews » Sat Sep 24, 2016 12:35 pm
ESTEE wrote:all of a sudden it is low. then it was ok - cant tell how it was fixed. then again now impossible to hear it is so low and quiet
We can't see your computer from here. Please use more words about what you are trying to play.
If you are recording something then playing that, what exactly are you recording? Is the recording too quiet (almost a flat line and not tall blue waves)?
