Hi,
I have a large file that I wish to split into 5 minute tracks all the way through. Is there a way to do this without having to manually go through the entire file labeling a different track every 5 minutes?
Thanks for all help
Splitting large files into timed tracks, not labeled tracks.
Re: Splitting large files into timed tracks, not labeled tra
Use Audacity 1.3.7
"Analyze menu > Regular interval labels"
When the regular interval labels are set, you can then use "Export Multiple" from the file menu.
Tip - to avoid having to click multiple times on the metatag editor pop-up, you can disable it in "Edit menu > Preferences > Import/Export tab".
