Help needed - slight ghosting on finished product
Help for Audacity on macOS.
Trebor
Re: Help needed - slight ghosting on finished product
Post by Trebor » Fri Sep 09, 2016 6:32 pm
kozikowski wrote:Cool. What settings did you use and which tool?
Paul-L's DeClicker on default settings, which reduces excessive K & T sounds.
I also equalized to reduce the deep valleys in the frequency-analysis.
Post by kozikowski » Fri Sep 09, 2016 7:32 pm
I'm in 25-step ToffeeDoodle Anonymous.
"My name is Koz, and I'm a ToffeeDoodle Compulsive."
"Hi, Koz."
I got it to pass and sound more natural, but it won't pass ACX Check because the clip has no half-second or more of room tone. About the best I could find is 1/3 second and that's not enough for the noise part of the tool to chew on. I did a manual noise check (the old way) and the clip really is into the -68dB range and passes, not -42dB that the tool thinks.
So, while you're cutting up raw work for the clip posting, can you make one and be sure you include at least 1/2 second continuous room tone. Do not fall to the temptation of creating silence with Command-L. That creates dead, surgically sterile silence and doesn't count.
I gotta drop out for a bit and do Real Life.
Post by kozikowski » Sat Sep 10, 2016 6:11 pm
I'm not completely sure which way to go with this. It's fairly certain that the excessive noise reduction is causing the sound distortion. It's famous for it. So use your tool pathway but use a lower Noise Reduction number. If you still have some odd, residual sizzly distortion, then try applying the DeEsser at the default settings. This is also where being able to hear accurately what you're doing is good.
7 - Sometimes I repeat the limiter at this point to bring the RMS down.
That's bothersome because the job of the limiter (and compressor) is to bring the RMS (Loudness) up. I wonder instead of that what would happen if you just normalized to a lower number. That will reduce distortion, too. The ACX Peak rating is a maximum. You don't have to hit that one, you just have to not go over it. RMS is a range goal.
LPF (Hz 16000 / Rolloff 48dB)
HPF (Hz 92.5 / Rolloff 48 dB)
Again, that high a reduction dB value is seen as a "brick wall" filter. Musical or vocal tones never get higher than 16000 (a bit crisper than FM radio). That may give you a warm, fuzzy feeling of having achieved your goal, but brick walls can cause sound distortion to the show that's left. Better to use lower numbers such as 36dB or 24dB.
I admit to being suspicious at your settings. 92.5Hz and 16000 Hz are not values that a New User would magically divine on their own. You had help, right?
ClaireJ
Post by ClaireJ » Sun Sep 11, 2016 2:43 pm
kozikowski wrote:"My name is Koz, and I'm a ToffeeDoodle Compulsive."
"Hi, Koz."
Hi Koz. My name is Claire and I am a soft-serve ice-cream with gooey toffee sauce compulsive.
"...Hi, Claire."
kozikowski wrote:I admit to being suspicious at your settings. 92.5Hz and 16000 Hz are not values that a New User would magically divine on their own. You had help, right?
You are too kind :-) I have just read at least a gazillion forum posts and googled the hell out of this. I hate wasting time and ineffective mastering is a massive waste. Plus I don't want to sound amateurish because then people won't buy my recordings and...(deep breath)...I'll have to go back to working in an office. In HR. Again (shriek!).
I did try to find an "Audio Mastering for Dummies" book, but it doesn't seem to have been written yet. (Hint Hint).
I haven't used the de-esser or de-clicker before, so will defo start doing that. Okay, sooooo my plan will be to normalise to a lower number and reduce the roll-off and see what effect that has. Limit my limiting (ha-ha) and go softer on the noise-cancellation. Passing the acx is such a headache, but this forum has helped so much!
A couple of quick questions:
- I haven't been equalising (because the screen confuses the hell out of me) and I thought low pass and high pass filters sort of did the same thing. I'm guessing this is a bit simplistic, in which case should I add equalisation into the process?
- I live near an airforce base so get jets flying overhead, am I right in thinking it's the HPF that targets that sort of sound?
Okay, so I've uploaded (another) sample with the 0.5s of room tone at the start. I don't know if you have time to get it to pass the acx check and see if there are any additional issues (with the extra room tone to check), but really appreciate it if you do!
Thanks,
Claire.
Home Ec - Closing Credits - Rough.wav
(1.77 MiB) Downloaded 21 times
Trebor
Post by Trebor » Sun Sep 11, 2016 6:58 pm
ClaireJ wrote: - I haven't been equalising (because the screen confuses the hell out of me) ...
It's possible to import equalization settings (curves) into Audacity's equalizer ...
The CJ#2 equalizition-curve imported into Audacity.png (43.53 KiB) Viewed 763 times
CJ#2.xml
Equalization curve data to be imported into Audacity equalizer
(106.23 KiB) Downloaded 38 times
Animation showing what CJ#2 does to frequency-content of '''Home Ec - Closing Credits - Rough''.gif
Animation showing what CJ#2 does to frequency-content of '''Home Ec - Closing Credits - Rough''.gif (40.61 KiB) Viewed 761 times
After equalization I think you're still going to need to apply the DeEsser and DeClicker.
ClaireJ
Post by ClaireJ » Mon Sep 12, 2016 4:39 am
Trebor wrote:It's possible to import equalization settings (curves) into Audacity's equalizer ...
Ok, I think I just fell in love. Thank you soooooo much for that Trebor!
Trebor
Post by Trebor » Mon Sep 12, 2016 6:13 am
After applying that precise equalization curve, CJ#2 ,
[ which removes the deep valleys from the frequency-response above 3kHz ]
You can make broad-changes to equalization to your taste using Audacity's "Bass and Treble" control.
NB: that equalization curve, CJ#2 ,is specific for the set-up you were using .
another curve will be required if you use a different microphone.
ClaireJ
Post by ClaireJ » Mon Sep 12, 2016 7:31 am
Trebor wrote:NB: that equalization curve, CJ#2 ,is specific for the set-up you were using .
Ah, okay, good to know. I won't be changing the mic until I actually start making some money (chicken/egg scenario) but what you've done has really helped out so thank you :-)
Post by kozikowski » Mon Sep 12, 2016 5:26 pm
ACX is very stern about consistency through the course of the book. So you won't be changing anything until after the first one. I live in horror of a Producer calling with the idea of scheduling a reshoot of a portion of a recording. "You do remember how you did it, right?" [email protected]#$%^
Effect > Equalization is the completely manual tool. All the others are minors or subsets. They're prebakes. You can manually drag the curve around toward the left and set the Length Value, yadda, yadda, or you can just use High Pass Filter. All baked in.
Steve's LF_Rolloff (which I think is called something else now) is a very specific, intentional, custom High Pass Filter, which itself is a pre-bake Equalizer. The joke is Steve has become internationally famous for writing seven lines of equalizer code.
<equalizationeffect>
<curve name="LF rolloff for speech">
<point f="50.0" d="-120.0"/>
<point f="60.0" d="-50.0"/>
<point f="65.0" d="-24.0"/>
<point f="70.0" d="-12.0"/>
<point f="80.0" d="-4.0"/>
<point f="90.0" d="-1.0"/>
<point f="100.0" d="0.0"/>
</curve>
</equalizationeffect>
Yes, but those seven lines work really well. If he solves world peace or human hunger, they will pale in comparison.
That's messy. That may be one of the conditions where ACX wants you to stop and wait for the planes to finish going over.
Jets have many different tones. High screaming as they approach (compressor blades in the engine) followed by roar as they go over (airfoil and wing noises) and then rumble after they pass (exhaust noise). They cover many if not all audible tones, not just high or low. You win!
I was in a position to hear the front and rear of a commercial jet. You would think the back of a jet strong enough to fling the airplane into the air would be loud, but it's nothing against the ear-splitting, demented screaming coming from the front.
I will reference Ian, the current champion of long forum postings. He lives on a noisy corner and records at night. Even I try to record at night. I can hear traffic passing in the background of my presentations. I know what it is. It's my non-sound proofed window. I just haven't gotten up enough effort to design and build a panel to cover it up. I'm not reading for bux, either.
Nobody's racing to write that book because it's too open ended. Mastering for what? AudioBook is a tiny subset of audio production.
"Well," you might well say, "write that one."
That's not what you or anybody else really wants. What everybody really wants is "Foolproof Disaster Recovery for Dummies." The goal is buy a Blue Yeti, record an audiobook on the kitchen table, become internationally famous and retire to a villa on Côte d'azur.
So not happening. There was a recent posting from someone promising "easy pro audio filters." What he meant was how to filter your "soundproofed studio recording" for sale. Not your kitchen table recording. Note the commercial grade soundproofing panels behind him. This was a difficult image to get, but I wanted that idea.
Everybody arrives with different problems and damage, so it's really hard to pre-bake rescues.
ACX itself has videos about how to do this. Step one: build a studio. Kitchen table need not apply.
http://www.acx.com/help/setup/202008260
[/cold-water]
Post by kozikowski » Mon Sep 12, 2016 5:35 pm
You're something of a special case because you arrived already closer than most people. My bag of tricks ran out. You're not disaster recovery. You're already close. That may actually be harder.
