USB device is recognized but no sound [SOLVED]
Help for Audacity on macOS.
tigergirl
Post by tigergirl » Sat Aug 27, 2016 1:26 pm
Hello all,
I just purchased an ION Tape Express to digitize a collection of cassettes of interviews with deceased family members. I was planning to use the included software, but it turns out to be a nightmare, so I'm hoping to use Audacity instead.
When I connect the ION via USB, Audacity recognizes it in the list of microphone inputs. However, when I press play on the device, no audio is registered in Audacity. I've just downloaded the most recent version of the software (2.1.2) hoping that would help, but same issue. I'm on a Mac using El Capitan (10.11.6).
A screenshot is attached of what I see when I hit play on the ION and record in Audacity.
Any help is much appreciated!
Screenshot of what I see when I try to record from the ION Tape Express
Screen Shot 2016-08-27 at 9.19.09 AM.png (127.71 KiB) Viewed 440 times
Reason: placed image inline so that it fits Forum layout
Re: USB device is recognized but no sound
Post by Gale Andrews » Sat Aug 27, 2016 1:34 pm
Make sure that USB PnP recording device is the Tape Express. If you are not sure, open Sound in the Mac's System Preferences, then disconnect and reconnect Tape Express and observe the name of the device that disappears and reappears.
Restart Audacity if you have disconnected and reconnected.
Then try turning the recording volume up (the slider with the microphone symbol):
Also see Recording with USB turntables or USB cassette decks - Audacity Manual.
cyrano
Post by cyrano » Sat Aug 27, 2016 1:37 pm
You must also hit "record" in Audacity...
tigergirl
Re: USB device is recognized but no sound [SOLVED]
Post by tigergirl » Sat Aug 27, 2016 1:37 pm
It was the microphone slider!!!!!! Thank you so much! :D
