I'm using Audacity 1.3.7 from debian sid.
I just created a big track containing 40 audio clips that needed editing (remove silence). Now I'd like to export each audio clip separately but I can't find an easy way to do so. AFAIK I can use multiple export on a single track only if I use labels and not audio clip. I could manually set a label at each clip but it's a long inaccurate and boring job. I googled around and found no answer. Any ideas?
Thanks!
how can I export each clip of a single track?
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Re: how can I export each clip of a single track?
Soved.
I didn't realize - since it isn't documented anywhere - that there is some magical auto-snap between audio clips, so placing the label is boring but accurate.
