downgrading from 1.3.8 to 1.3.7?
waxcylinder
Re: downgrading from 1.3.8 to 1.3.7?
Post by waxcylinder » Sat Mar 28, 2009 6:36 pm
allencmcbride wrote:I just saw this post from Gale, which implies that under at least some circumstances you can have 1.3.7 and 1.3.8 installed at the same time - Allen
Certainly works on my Windows XP machines - where I have both 1.3.6 and 1.3.7 (and even 1.3.5 and 1.2.6) all installed.
They are carefully installed in differently named folder areas (named to differentiate the versions) rather than the default that Audacity tries to load in. I can fire any of them up ok - but not at the same time as each other. But I do realize that that they are all working off the same preferences file - but apart from that they don't impact on or interfere with each other.
allencmcbride
Post by allencmcbride » Mon Mar 30, 2009 1:51 am
Thanks. Synthesizing this, Gale's response in another thread, and what Koz has said, this sounds like a difference between Mac and Windows. --Allen
Post by kozikowski » Mon Mar 30, 2009 2:53 am
Or maybe not.
I have two requirements that use different 1.3 versions on two different Mac boots. The regular, boot from the system drive, check the email, OS is Tiger running 1.2.5 and 1.3.6 just because that was the last one I installed and it seems to be reliable enough to do what I want. 1.2.5 is stable on Tiger but not Leopard.
I boot clean to an external drive and Leopard and that's the development system with the daily downloads of each installer. I need to make absolutely sure that none of the old Audacity is left hanging around when I install the new one.
I've always followed the Party Line against trying to manage multiple Audacities. There are enough problems without tempting fate. See:
<<<where I have both 1.3.6 and 1.3.7 (and even 1.3.5 and 1.2.6) all installed.>>>
