Editing
Fred Svoboda
Editing
Post by Fred Svoboda » Sat Aug 20, 2016 10:42 am
Good morning everybody,
Windows 7
I have recorded music from tape cassette. Everything is OK except that I do not know how to split it to individual songs (tracks). Can someone advice, please?
Best regards
Fred SVOBODA
Reason: email address removed to protect user's privacy
Re: Editing
Post by steve » Sat Aug 20, 2016 10:54 am
You need to split the recording into separate files. You can do this by placing labels at the start of each 'song' and then using "Export Multiple".
More details here: http://manual.audacityteam.org/man/spli ... racks.html
If you intend to make an audio CD, the CD burning software will handle making a compilation of the tracks in the right order.
If you intend to play the tracks on an MP3 player, you can create a playlist to tie the tracks together into an 'album'.
Fred Svoboda
Re: Editing
Post by Fred Svoboda » Sat Aug 20, 2016 12:29 pm
Thanks Steve
Fred
