Can someone help me remove voice from a song
For Musicians to Share Their Music, Tips, Tricks and Reviews.
blancaFan
Operating System: Windows XP
Post by blancaFan » Fri Aug 19, 2016 2:04 am
Hey guys, I assume there is someone here with audacity that can assist me. I currently don't have audacity and was wondering if someone can help me remove the voice from a song for me. There are a lot of smart guys and girls here and hope someone can help. thanks.
Re: Can someone help me remove voice from a song
Post by kozikowski » Fri Aug 19, 2016 3:35 am
We can tell you how to try yourself.
Run Audacity.
File > Import and point to your song.
Effect > Vocal Reduction and Isolation. Try it with the default settings.
Vocal Reduction is not a sure thing. If your song fails or there is too much damage, then it may never work. You might look at buying a karaoke version of the song.
blancaFan
Post by blancaFan » Fri Aug 19, 2016 12:11 pm
I do not have audacity. I am really hoping someone here can help me omit the voice. I have the music file. For the song I want to, there is no karaoke. I'm planning on signing winter wonderland by blanca for a hospital benefit December 1st. Please, any help is appreciated. You have my full cooperation!
Post by steve » Fri Aug 19, 2016 12:28 pm
blancaFan wrote:I do not have audacity.
It is available (free) from here: http://www.audacityteam.org/download/
We're not here to do it for you. We're here to help Audacity users to get the best out of using Audacity.
S AnShu
Post by S AnShu » Mon Aug 22, 2016 2:32 am
blancaFan wrote:Hey guys, I assume there is someone here with audacity that can assist me. I currently don't have audacity and was wondering if someone can help me remove the voice from a song for me. There are a lot of smart guys and girls here and hope someone can help. thanks.
Try this -
Effect => Vocal remover => apply this nd then => go to Equalization => Just change the db of -20 no. ....
Just try :)
Post by steve » Mon Aug 22, 2016 10:27 am
Audacity 2.1.2 has two effects for removing / reducing vocals from a song. There is no guarantee that either will work. The effectiveness of these effects depend on the amount of stereo separation. Both effects are fully documented in the manual:
The old effect: Vocal Remover http://manual.audacityteam.org/man/vocal_remover.html
The new effect: Vocal Reduction and Isolation http://manual.audacityteam.org/man/voca ... ation.html
