Locating section to be acted upon
Help for Audacity on macOS.
Niku
Post by Niku » Sat Aug 13, 2016 10:33 pm
Oftentimes it is necessary to zoom-in to find the precise area to be fixed with various methods. The problem is that the zooming-in process moves the target off the screen. There are ways to move the file to the left or right, but they are too crude. They overshoot the mark. Is there a way to gradually and precisely move the file in order to reach the target? Say you want the section from 2.5 to 2.6, how do you get there? In other words, I'm looking for a fine-tuning method. Does it exist?
Trebor
Re: Locating section to be acted upon
Post by Trebor » Sun Aug 14, 2016 12:19 am
Niku wrote:...Say you want the section from 2.5 to 2.6, how do you get there?
Select the region [ from 2.5 to 2.6 ] the press Zoom Selection Image
zoom-in on selection.gif (130.29 KiB) Viewed 162 times
