The noise sample only needs to be a second or two. You can attach that here as a WAV file.Niku wrote:I just tried to send you some 'silence," It was a tiny little clip, but it was 48.4 MB.
Code: Select all
Complete name : ./The Rubaiyat of Omar Khayyam 2-cr1.wav
Format : Wave
File size : 172 KiB
Duration : 5s 468ms
Overall bit rate mode : Constant
Overall bit rate : 257 Kbps
Album : Angel at Radio Shack
Track name : The Rubaiyat of Omar Khayyam
Performer : Omar Khayham
Composer : Omar Khayham
Director : Omar Khayham
Genre : Pop
Recorded date : 2007
Original source form/Name : Angel at Radio Shack
Comment : 00000000 00000210 000004B0 0000000000B88D80 00000000 001BA200 00000000 00000000 00000000 00000000 00000000 00000000
Encoded by : iTunes v7.1.1
BPM (beats per minute) : 120
Audio
Format : PCM
Format profile : Float
Codec ID : 3
Codec ID/Hint : IEEE
Duration : 5s 468ms
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 32 bits
Stream size : 171 KiB (100%)
