Incidentally, I resolved this by rebooting the program.I mistakenly clicked on Time Shift and now cannot 'unclick' it. How do I do that? I looked in the manual, but it doesn't seem to address that issue.
Thanks,
Bob
Bob
Thanks,
Bob
I've been wrestling with these missing files for three hours. The project is finished and awaiting Export, but until I can figure out this glitch I am stuck.I just scrolled down to Track 15 in Metadata. By the time I reached number 15, three tracks had 'dropped out'. I haven't gone on to number 70, but at this rate, if I had I am sure there would be many more missing. As I said in the last post, all these tracks are numbered sequentially, starting at 201 and ending at 270.
Time Shift and the other tools in Tools Toolbar are not a toggle. Once clicked, they are "on" until you click the button for another tool. So, click the I-Beam button to go back to Selection Tool.Bob Bell wrote:I mistakenly clicked on Time Shift and now cannot 'unclick' it.
I understood you to mean that you have 70 Audacity tracks stacked on top of each other. If so, choose to Split files based on tracks.Bob Bell wrote:I've been wrestling with these missing files for three hours. The project is finished and awaiting Export, but until I can figure out this glitch I am stuck.I just scrolled down to Track 15 in Metadata. By the time I reached number 15, three tracks had 'dropped out'. I haven't gone on to number 70, but at this rate, if I had I am sure there would be many more missing. As I said in the last post, all these tracks are numbered sequentially, starting at 201 and ending at 270.
I am unsure of what you mean here Gale. I see in the Edit menu, under Clip Boundaries, there are two differing Split commands. Is it one of these I am to use? I tried using Split, but it made no difference. Is it possible that during my editing, with the tracks stacked on top of each other (even in the Align Tracks mode), two tracks are ever so slightly NOT separated? Is this why you are suggesting Split?I understood you to mean that you have 70 Audacity tracks stacked on top of each other. If so, choose to Split files based on tracks.
If you have any tracks with the Mute button down, they won't be processed for export.
Sorry, that means choose "Split files based on tracks" in Export Multiple.Bob Bell wrote:I am unsure of what you mean here Gale. I see in the Edit menu, under Clip Boundaries, there are two differing Split commands. Is it one of these I am to use?I understood you to mean that you have 70 Audacity tracks stacked on top of each other. If so, choose to Split files based on tracks.
SHIFT + S only solos or unsolos the single track that has the yellow focus border.Bob Bell wrote:How does one switch on the Solo button for all 70 tracks at once?
I tried Select all and then Shift-S but nothing happened.
I have been using the Export Multiple command. I have my 70 tracks in sequence, all numbered appropriately. Yet when I go to Export Multiple, it leaves some behind.Sorry, that means choose that option in Export Multiple.
Well, there is a point because i am going through each track, listening to the last ten seconds and the first ten seconds of each one to check on sound levels. Having all the solo buttons 'on' smoothes out the process.There is no point soloing all the tracks because that is the same as having no Mute or Solo buttons down on any of them.
It should not do that if you are choosing "Split files based on tracks" and if no tracks are muted.Bob Bell wrote:I have been using the Export Multiple command. I have my 70 tracks in sequence, all numbered appropriately. Yet when I go to Export Multiple, it leaves some behind.Sorry, that means choose that option in Export Multiple.
Having all Solo buttons on is still the same as having no Solo buttons on and no Mute buttons on.Bob Bell wrote:Well, there is a point because i am going through each track, listening to the last ten seconds and the first ten seconds of each one to check on sound levels. Having all the solo buttons 'on' smoothes out the process.There is no point soloing all the tracks because that is the same as having no Mute or Solo buttons down on any of them.
