win 7 64 bit Audacity 2.1.1.
Can the new version be installed over the old?
Installing new version [SOLVED]
jack magee
- Operating System: Windows 7
waxcylinder
Re: Installing new version
This page from the draft Manual for the upcoming 2.1.3 release should explain it all: http://alphamanual.audacityteam.org/man ... on_Windows
jack magee
Noted, thanks. I am curious about the zip option. Wouldn't you still need to run an exe from inside the zipped version? Or is it portable?
- Quality Assurance
You asked about installation. For that, download and run the installer, not the ZIP.jack magee wrote:I am curious about the zip option. Wouldn't you still need to run an exe from inside the zipped version? Or is it portable?
If you use the ZIP, after extracting all the files from the ZIP, just double-click on "audacity.exe" to launch Audacity. That "audacity.exe" is Audacity itself. There is no installer (such as audacity-win-2.1.2.exe) inside the ZIP file.
jack magee
Re: Installing new version [SOLVED]
understand now thanks. install fine with me was just curiousYou asked about installation. For that, download and run the installer, not the ZIP.
