Why does Audacity go to new track when paused? [SOLVED]
jack magee
Operating System: Windows 7
Post by jack magee » Mon Jul 25, 2016 8:40 am
Win 7 64 bit. Audacity 2.1.1
When I record two pieces from the net I have to pause Audacity at the end of the first to ready the second. When started again instead of continuing from where it paused it goes to a new track. To put them together as one mp3 I have to copy the lower track and paste it where the first part ended. Is there a way to have is start from the same place it paused on the same track?
waxcylinder
Re: Why does Audacity go to new track when paused?
Post by waxcylinder » Mon Jul 25, 2016 9:12 am
If you really use Pause and then Pause again when recording this will continue recording on the same track.
If instead you Stop and then press Record again, yes a new track will indeed be created.
You can make it stay recording on the same track after a Stop by using Append Record:
a) hold the Shift key down while pressing the Record button (note that the button icon changes when you hold the Shift key)
b) use the keyboard shortcut Shift + R
c) or use the menu command Transport > Append Record
jack magee
Re: Why does Audacity go to new track when paused?[SOLVED]
Post by jack magee » Mon Jul 25, 2016 11:03 am
Sorted, thanks
