EQ
Canary
EQ
Post by Canary » Sun Jul 24, 2016 11:34 pm
I am using Windows 10
I have no idea which three section version I'm using
I simply downloaded audacity some months ago and I use it all the time
1st question
The manuals and such hint at a simple downloadable EQ only I can't find it.
2nd question
Audacity returns me a stereo .wav file.
Is there some way I could have a mono .wav file returned to me?
thank you, Canary
Re: EQ
Post by kozikowski » Mon Jul 25, 2016 2:15 am
Audacity should produce a mono WAV export if all the work on your timelines is mono and you have all your track pan controls centered. Are they and do you?
You can change the character of single blue-wave tracks with the drop-down menu from the little black arrow to the left of the track. Mono is one of the options.
If you have a stereo show in the production, you can convert it to mono by selecting it (click just above MUTE) and Tracks > Stereo Track to Mono.
Any luck?
Trebor
Re: EQ
Post by Trebor » Mon Jul 25, 2016 3:46 am
Canary wrote: 1st question
There are free EQualizer [VST] plugins which work in real-time if you use the latest version of Audacity,
e.g. ... http://forum.audacityteam.org/viewtopic ... 23#p293923
Canary wrote:Audacity returns me a stereo .wav file.
If you go to audacity preferences you can set preference to record as 1 channel (mono) or 2-Channel (stereo) ...
http://manual.audacityteam.org/man/devi ... ences.html
Re: EQ
Post by kozikowski » Mon Jul 25, 2016 4:29 am
My Audacity 2.1.2 appears to export a mono WAV from a mono timeline even though my device toolbar says stereo.
Re: EQ
Post by steve » Mon Jul 25, 2016 7:21 am
kozikowski wrote:If you have a stereo show in the production, you can convert it to mono by selecting it (click just above MUTE) and Tracks > Stereo Track to Mono.
Described in the manual here: http://manual.audacityteam.org/man/trac ... tereo_mono
kozikowski wrote:My Audacity 2.1.2 appears to export a mono WAV from a mono timeline even though my device toolbar says stereo.
Yes the channels settings in the device toolbar is a setting for the number of channels to produce when recording.
