Can't run Audacity 2.1.2-4 on Fedora 24 / strange errors.
Please state:
polemon
Operating System: OS X 10.6 Snow Leopard or earlier
Post by polemon » Sat Jul 09, 2016 12:21 am
OK, so I've installed Audacity 2.1.2 on Fedora 24 from the regular Fedora repos (audacity-2.1.2-4.fc24.x86_64), but I'm getting very strange errors:
when I'm trying to start audacity from command line, I get this error:
Code: Select all
% audacity
audacity: symbol lookup error: audacity: undefined symbol: _ZN4FLAC7Decoder4File4initERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE
This occurs, even when starting with --help, or any other command line switch.
When I try to start Audacity from the Applications menu, it does open, but this is what I see:
As you can see, the control buttons (stop, play, pause, etc.) are missing, instead there is like a blank space or something. I can't get rid of it no matter what I do.
I don't really know what happened here, or why these errors occur. Audacity seemed to have worked somewhat nice on Fedora 23, but on F24 things are a little wonky.
Any ideas?
Re: Can't run Audacity 2.1.2-4 on Fedora 24 / strange errors
Post by Gale Andrews » Sat Jul 09, 2016 11:50 am
That looks like a packaging problem. You may need to install a different FLAC package. We can't help with that. Ask here: http://www.forums.fedoraforum.org/.
Please let us know if they offer a solution.
