Help on how to reproduce a certain effect
For Musicians to Share Their Music, Tips, Tricks and Reviews.
Frousties
Post by Frousties » Wed Jun 08, 2016 5:59 pm
Hello,
I casually makes covers of my favourite songs and I try to make them the closest to the original (and so with effects)and with one of them, I had difficulty on reproducing it so I ask for your help.
I want to make the effect present in this video between 0:48 and 1:00
https://youtu.be/Q_QEPrkwZ-Q?t=48s
I have tried with high pass filter but it is not what I've wanted.
So, please, can someone help me ?
Thanks
Re: Help on how to reproduce a certain effect
Post by steve » Wed Jun 08, 2016 6:52 pm
It sounds to me like a "phase vocoder" effect. You probably can't get that exact same effect with Audacity because it is usually accomplished by pitch shifting under MIDI control, and Audacity does not support MIDI control. You may be able to achieve something similar using GSnap (an optional VST plug-in) by twiddling the controls to fairly extreme settings. The GSnap website is here: http://www.gvst.co.uk/index.htm Audacity requires the 32-bit version (Windows only).
Frousties
Post by Frousties » Wed Jun 08, 2016 8:07 pm
Mmh, I've tried GSnap, but I see no way to reproduce the effect I want(even close)
Trebor
Post by Trebor » Wed Jun 08, 2016 9:16 pm
There is a free plugin called DTBLKFX , which works in Audacity (on Windows).
DTBLKFX will shift the pitch in the left channel to match the pitch of the note in the right channel.
So play the tune with a simple sine-wave, sing along, then pitch-shift singing to match tune with DTBLKFX ...
DtBklFx HarmRepitch ( poormans autotune).png (217.66 KiB) Viewed 634 times
